Gearbox oil through speedo cable
Hi Guys,
I run a 1998 petrol 'Felicia' 1.3 litre, low mileage, less than 45000 miles. Having arrived home one day I noticed oil in the centre consul. Thinking that it was the headlamp adjustment leaking I removed the instrument panel and discovered that the oil was in fact coming up the speedo cable. It has made rather a mess in the instrument panel and inside the car.
A new cable was fitted but it has made no difference. The gearbox/transmission oil level is OK. A bit low if anything.
Having been in Engineering for nearly fifty years I started to look for a breather on the transmission unit thinking that this might have become blocked. However I cannot find one.
Is there a breather on the transmission, and if so where is it?
Thanks, hopefully.
nope, no breather on the transmission, it's totally sealed!!! quite a common falut that, oil coming up through the centre of the speedo cable..
There is a breather tube and plug on the top of the gearbox, these get stuck up and then the box pressurises.
?? i thought that breather was for the clutch to allow the air to circulate more freely??
It's under the clutch arm.
What a horrible design, a bit of plastic on top of the gearbox. Done for cheapness no doubt. I had a hell of a job getting the bloody plastic to move where it had rusted in, even with the clutch pedal fully depressed (jammed it down with a piece of wood) and using 'PlusGas'. Unfortunately the damned plug had rusted in and broke off.
Solution was a piece of 8mm copper tube (fitted exactly) 'cut and shut' in a right angle and soldered, the short leg 20mm the long leg 80mm and locktighted into the breather tube. Makes a better job than Skoda's original.
The plastic plug came out when I changed the gearbox oil, so all's well.
  • 1 year later...
Hi Guys
Also having problems with oil coming up the speedo cable. Have located the breather and managed to move it so that it's proud of the gearbox; it was originally flush with it. But it doesn't move up and down as I suspect it supposed to? WD 40 not done anything, any ideas to get the bloody thing working?
