Fitting Stereo
Hi,
I attempted to fit my Kenwood stereo in my vRS tonight but had to abort. I managed to connect it up and get it working on an aux connection from my TomTom that I can play iPod via. I found a route that I can use from the centre console so the cable runs upto my TomTom on the very right of the windscreen.
I've had a search on the forums already but I have the following questions:-
  1. Do I need to use the metal cage to properly mount the Kenwood unit above the tray? If so how do I get it to fit? :confused:
  2. I managed to scratch the rear heater button when trying to fit the metal cage. How much do these tend to cost, and can I just pop that out and another in? :rolleyes:
  3. The arial connector on my Kenwood won't fit with the Fabia's. Will an antenna amplifier adaptor allow them to connect? :confused:
  4. What's the best way to clean the seats? I got blood from my finger on the passenger side! :finger: I sponged it out I think, but won't be able to tell until dry.
I was going to just wire it in and use it purely for iPod until I got the right aerial adaptor, but I couldn't get the stereo in properly, so I decided to put the standard Symphony one back in for now.
Cheers!:thumbup:
Answers as follows:
1: Yes, but it's a b4st4rd to get in. I had to shave off some of the plastic that the tray sits on with a sharp chisel. It stops the tray sliding in otherwise as it sticks up. You'll see where the tray has caught when you shine a torch in there.
2: Dunno, but I doubt it's a lot.
3. You need the adapter. Luckily I had one that I'd never used. It came with the Kenwood.
4. Do a search. I used Autoglym Interior upholstery cleaner and it's 'ok' but could be better. I imagine 1001 does a good job. ;)
Thanks for your advice. I'm glad I'm not the only one. I tend to be ok at doing these things and often get everything to work, I just end up scratching things a bit on my first attempt.:(
Hi,
Cheers!:thumbup:
1) yup, as Chrispy already said, you must shave some of the tray off to allow the cage to fit in. Although, I did not have to modify my cupholder when that was put in so I suspect it is just a problem with the trays unfortunatly.
2) Try a scrappy
3) Might be another connector in the box with your radio, took me a while to sus it out but its like a bullet shape.
4) I used car plan upholstry cleaner - until I got some "Bissel" stuff which is probably the same but worked a treat. Simply spray, rub then wipe. Not sure about blood though.
