Asr & Abs
I have read that the traction control system in the vRS uses the ABS sensors.
As such, does disabling the traction control also disable the ABS?? Just asking so if I track the car, I know if I need to take out the ABS fuse or just disable ASR.
No...
ABS is still active in all conditions..
on my fabia i have esp if i switch it offf a couple of times my car has actually locked up i thought it disabled everything when you turnt it off
