EGR cleaning
I cleaned my EGR out over the easter weekend... some pictures:
Before cleaning, still attached to car:
http://www.matthewames.co.uk/briskoda/20070409_egr/PICT2894.JPG
http://www.matthewames.co.uk/briskoda/20070409_egr/PICT2895.JPG
http://www.matthewames.co.uk/briskoda/20070409_egr/PICT2896.JPG
http://www.matthewames.co.uk/briskoda/20070409_egr/PICT2897.JPG
Taken off and now you can see how dirty and clogged up it was
http://www.matthewames.co.uk/briskoda/20070409_egr/PICT2898.JPG
http://www.matthewames.co.uk/briskoda/20070409_egr/PICT2899.JPG
http://www.matthewames.co.uk/briskoda/20070409_egr/PICT2900.JPG
http://www.matthewames.co.uk/briskoda/20070409_egr/PICT2901.JPG
Cleaned:
http://www.matthewames.co.uk/briskoda/20070409_egr/PICT2902.JPG
http://www.matthewames.co.uk/briskoda/20070409_egr/PICT2903.JPG
http://www.matthewames.co.uk/briskoda/20070409_egr/PICT2904.JPG
Split hose:
http://www.matthewames.co.uk/briskoda/20070409_egr/PICT2906.JPG
What I did not do was clean the air intake manifold as I could not be arsed with taking it off the car (plus I wanted to only do one thing at a time), but I did insert my finger into it and scoop out some horrible black thick/googy oil from it, so I guess that can't have helped either.
The split hose in 2906 is the vacuum hose that controls the butterfly (anti shudder) valve. I just cut the end and refitted it
I also changed my ARB bushes as they were knackered.... that has improved the feel of the car a great deal. Plus is no longer clonks over speedbumps.... but as a downside my handbreak kn0b rattles now :eek:
Oh and then the wire in the drivers door attached to the internal handle broke on Tuesday when I got to work.... :mad:
Not as bad as I thought from what you said, but looks a darn site cleaner.
Where was all the external oil coming from and glad you appear to have your turbo back after fixing that pipe :)
external oil seemed to be coming from the breather hole towards the top of the EGR - just under the vacuum unit in 2987
Looks good nice job makes me even more determined to do mine :thumbup:
It seemed to have a marked perfomance change for the car, so I am happy, plus finding the split vacuum hose.
I was able to do mine without replacing the gasket either (although I have bought a new one just incase). It can be a little bit difficuly getting the 3rd allen screw out of the bottom of the EGR, but you can flex the pipework enough to get an allen key in....
