oil pressure
Hi Guys/Gals
I drive a Felicia 1.3 GLXi 1.3 l petrol and recently I have noticed the oil light flicker
when the car is ticking over. The oil level is at the upper level I know the switch only measures oil pressure what would cause the oil pressure to drop.
:confused:
Hi there.... i have had this problem on my felicia 1.3
Do you notice any noise at higher revs or with maintaining your speed at around 55+ mph?
:confused:
oil pump worn out.
pickup/strainer blocked
dirty oil
incorrect filter fitted
Thanks fellows
I'll give her an oil and filter change and see what happens
