Felicia 1.9D fuel system
How to check the diesel injector pump timing?
When fitting a new cam belt recently, I used the crankshaft mark ( bell housing inpection hole), the cam holding tool (with equal feeler gauges each side to take out any slack) and injection pump locating pin.
Are there any other checks that I can do to verify that the injection system is set up for maximum fuel economy?
Many Thanks,
Sea Kayaker
Edit: Before, and after Cam Belt change, I get 55mpg on long runs, but want to improve on that figure.
