Boot is about finnished now !
Been having a play for the last few weeks on a new boot install as the old one was a bit naff
Took pics as i went as we all like install pics :rolleyes:
Ripped the CD changer out and wacked some sound deadening behing the carpet
Half a ton of tape later
then covered in tinfoil and more tape
2-3 layers of fiberglass drying
This stuff stnks in the car was about wasted when i drove to work the next day
Removed from the car spent aged removing all the foil and tape
kids do have there uses at least :o
and rough trimmed to size
Cut the front out of MDF and screwed to the fibreglass back
More fibreglass on the back and 3-4 more layres inside
Loads of sanding, Bodyfiller, more sanding and a lick of black paint before trimming in carpet
two sections of false floors painted black and trimmed in faux suede
with the amps mounted and power cables all braided
Forgot to take pictures of the floor lids but there painted black before carpeting and putting in Lexan windows (care of work :rolleyes: )
all fitted
with the PC at the front
just need to put some sort of lighting begind the windows (probly those thin cathode lights)
and then to start on some front speakers
comments or suggestions welcome :thumbup:
Is that an Alpine MRV T1505 ? neat install :thumbup:
Looks like a similar set up to mine:thumbup:
Those are jolly need installs. Most impressed.
Very tidy :thumbup:
Neat installs - at least it leaves the boot still useable and you haven't got a loose sub box "missile" ready to brain you if the worst did happen.
A question please - where did you get the carpet from? It looks a very good match to the original.
Awesome looking install. Good job. Did you actually work out the volume of the fibreglass box, or did you just make it and whack the sub in? I'm always curious if people bother when using fibreglass, as I bet its a PITA to get a volume for!
It isn't that difficult.
As fibreglass is water tight - or should be, you can use water to find out the volume.
Most of the time, the basic size is half calculated, half a guestimate, then either filled with water or something like polystyrene balls to work out the true volume.
If it's too small then there is a bit of work to do, but too large and you can simply use lumps of wood or something similar to take up the volume.
