6 Speed Gearbox On Ebay , Will It Work?
It was off a quattro, so I imagine not?
Don't you just need to blank off the transfer box part of the gearbox ?
won't work.
That's right. Works fine on a 2wd. TT/S3 drive shafts will be needed and a 6spd clutch and flywheel. I also think the starter motor has to be replaced too IIRC.
i was told you couldn't do that, or am i getting it the wrong way round and you cannot run it as RWD only? :rubchin:
It can definetly be done, it's how all the 6spd FWD conversions used to be done before a 6spd FWD was available. Gary Handa's Mk4 Golf (better known as MRK IV due to the private plate) is probably the best known example but there's plenty of others out there.
