Estate rear bumper fitting
Im on the lookout for a rear bumper for my MKI estate (X) as it has been very slightly shortened at
some point then filled & sprayed badly
Theres one ive just found on ebay which is from an 03 estate and what i need to know is will it
fit straight on or possibly easily enough to make it a worthwhile purchase
Looks the same in the piccy but just need to know for sure
cheers all
If yours is a facelift Mk1 then it will be the same.
The facelift would be the one with the spots in the front bumper ?
If so then no its not :(
No a facelift model has the fogs in the main lights which are the clear optic type.
Ah ok Eddy i see like this you mean ?
http://www.hold-tight.co.uk/octy%20front.jpg
and this is the bumper in question
http://www.hold-tight.co.uk/octy%20back.jpg
cheers
WOAH!
What's going on there? Nothing fits. It looks like a pre-facelift car fitted with facelift lights, grille and bumper. Hence the big gaps and the grille profile not matching the bonnet.
Is that a photo of your car? What model is it?
yes that is my car ! the gaps between the grill lights and bumper are because the
bumper has dropped slightly and squashed up in the middle after a mild front
shunt and i have a cross member (if its needed) and a new bumper ready to
go on
I do see what you mean about the gaps above the lights though
and its not something i had noticed untill now viewing it at that angle :confused:
go on
The top of the grille also looks to be a different profile to the bonnet. I think the changeover for the facelift was around 2000. One of the pre facelift models was the SLXi what model is yours?
Its a 2000 model (X) TDI Ambiente
I believe your right Eddy its a bit of a mish mash that grill is facelift
and the bonnet isnt
The rear definitely looks like a facelift model. I think there's more damage to the front than you think though. The headlights look to have dropped and the grille may have been bent backwards hence the top not lining up.
However to answer your original question the rear bumper from a 53 plate Octy Mk1 will fit.
and the bonnet isnt
Yes the grille is a facelift one, however it could be an alignment problem as mentioned in my post above. It should all look alot neater than it currently does. The bonnet and grille look different shades of white in the pic. Hopefully it won't be too much trouble to get it all sorted.
At some point soon the front end is coming off anyway to have the
new bits fitted so ill see then just what its like underneath
Thanks for your replies mate much appreciated
