PAS with a mind of its own!
Ok folks whats your thoughts....
Sometimes my PAS starts the wheel twitching (not a lot but you can feel it , especially when turning one sec its heavy, next very light) , the voltmeter is jumping up and down like a silly thing. Happens at irregular intervals. Switching off and restarting cures it sometimes for only a short while, sometimes for a long while.
Please someone tell me its a cheap fix....
dodgy battery ?
faulty sensor ?
dodgy battery ?
faulty sensor ?
Battery good was thinking sensor, anyone able to shred any more light
Steering angle position sensor is a common problem with the earlier Fabias (think its called the yaw sensor). Not sure if its failure gives these symptoms though.
Any chance of getting VAGCOM hooked up for a scan?
I think you have 3 options here , Steering angle sensor , Power steering pump , or steering rack. If I was you I'd visit the nearest Church and pray its the sensor! IIRC the pump is about
Power steering has its own battery - did you check that one or the main one?
the first thing i would check is if there is enough fluid in the system
