EML on then off?
I had the engine management light come on last week for about 4 or 5 days with no loss in performance, everything seemed as normal.
Yesterday the light seems to have reset itself so now it's off and things are as before.
I'm wondering if I should get this checked or whether it was just a slight sensor malfunction?
Will the fault be stored and will Vagcom be able to see what it is?
It's a 51 plate Octy Vrs but I don't think knowing the specific model matters but always worth addin it just incase.
Vag com will store a fault code sounds like something is faulty but may be intermittant
hi bigal rallyred,i have vag com if u need it checked out,im over in fife,im a fully qualified mechanic.give us a shout
Thanks for the offer :thumbup: , if it comes back on I'll give you a shout.
As i said the car seems to be running as normal, to be fair it's only done less than 1000 miles since christmas so maybe it just needs a good run!
It's people like you that make the forum what it is, can't express how much help and advise I've received in the 2 1/2 years since joining.
I had exactly the same for about 10 days then the light went off, it went in for a service and they did a diagnostic and it was showing a fault code for the lambda sensor, HTH!
No problems since it went off!
