Rero fit EDL & ASR
Looking at the Mk1 Fabia brouchure I notice that the above are a Factory Option for fitting to the Bohemia Estate for all of
Suspect it can be done, but the ASR is very crude and tends to cut power when you most need it, so I personally wouldn't bother! If you want to retrofit some kind of traction control, you'd be better looking at ESP, but cost may be prohibitive here....
Chris
I don't think it would be feasible.
Apart from the wiring differances you'd need a new slip ring on the steering column and possibly a different controller.
I've found it very useful in the snow last year, only 4x4s had more grip! If it has so much extra I wonder why it only costs
When I mentioned the new slip ring etc I was reffering to the ESP that Chris mentioned which is around
dont racelogic offer a tc system.
Well they've come back to me, it seems the Cruise is no problem (as I knew!), but they can't do the EDL/ASR, so I'd have to live with just the ABS. Can't understand for just
You could possibly install the CC yourself. Guide on my Fabia website.
