Neuspeed Rear ARB
Simple question, is the 28mm rear anti roll bar (which is available for the octy) likely to cause rear end traction issues under hard cornering?
If you set it to the stiffest setting you can get oversteer.
I had mine on the middle setting and had no problems.
mine is in the middle setting without any problems.
tightens the rear end up nicely!!!
