Help Part Numbers Needed!!!!! (Please)
Need a bit of help trying to find part numbers for a few bits on the 1.9SDi classic estate (53 reg) :confused:
Variant : SEASYX01
Version : FM5FM52T030LALLE0GZ
ASY Engine
I need to get a few bits for the monster but don't want to go to the local stealers and get ripped off!! :rofl:;)
Can anyone please let me know what the part numbers (skoda or OEM) are for the following bits for my car : Front Brake Disks, Front Brake Pads (no wear indicator) and Oil Pressure Switch. :grouphug:
If there is any other information required please let me know - oil pressure switch getting imminent (leaking through the switch) Disks and pads may last a couple of months but starting to get a bit of brake fade with the disk wear the way it is. :rubchin:
TBH if you are going non genuine then there is little point in having part numbers, simply ask the supplier for a suitable part and they'll look it up for you.
If you became a freedom member you would be entitled to a discount from German, Swedish and French.
The Oil Pressure Switch should be 038 919 081 C (0.55-0.85Bar 1 Pin Brown).
did a search on the Oil pressure switch number and found this site : JHM Butts & Co Ltd
Anyone used them for parts??
I beats me why people assume that the parts they buy from Skoda are going to be well overpriced, perhaps you've all had too many Fords or Vauxhalls. According to my information that part is about
Stu,
I would normally use the stealers for my parts. the only thing is the last time i used them they tried to say i'd scre*** the engine on a courtesy car and now under principle i will not use them ever again and have told all my family and friends what they are like as well.
Hence searching the net for parts.
In this instance you could buy that part from VW/Audi or SEAT.
It would seem to me that it might be the easier option.
Just been in touch with the main stealers
Oil Pressure Switch : 038919081C -
Not bad then really.
That sounds very reasonable imho.
Disks for my 6N Polo were
Got the Oil Pressure switch from the local car spares shop
