Instrument Cluster Query
According to both my user handbook and the Haynes 'manual', the display in the centre of the instrument cluster should display oil level info and other information for about 20 seconds when the ignition is turned on.
However, mine only displays the brake-pad warning light, fuel level, door open etc but no other text or graphics. Is this correct or is my instrument cluster knackered? And if so, can it be repaired?
Thanks in advance.
dont worry. mine doesnt do this either, dont think its available in this country.
IIRC it still warns you of low oil.
Neither does mine. I don't think my Haynes even claims that there's an oil level readout in the car.
are mk1 vRS models supposed to have brake pad warning sensors and indicator?
Yep
Yep
hmmm.. ok, i'll have to have a closer look - I was sure neither of my front pads had sensor wires on, maybe the car side connector is tucked away in that case :confused:
Would that be sensors on both left and right sides or just the one then?
