Mk1 vrs rear wheel bearing
What's the deal with changing one, is it easy, will I need any special tools? Cheers guys & gals.:confused:
Nothing too special except a big socket (30mm iirc) and a big torque wrench.
I think you may need a two or 3 pronged puller to pull the hub off and then to pull the bearing off the shaft according to haynes.
Normally they knock off and should come off complete.
