Mother Board...HELP!!
Howdy....
Basicly my M/B is foobard, and it's a small miricle that my PC works at all!
I've picked up a new M/B today but I was just wondering if I HAVE TOO reformat my hard drive, or can I get away with just swapping them and loading the new software?
Bobz
If your new motherboard uses exactly the same chipset(nvidia nf4 650/680 intel 965/975 etc) as your old one then you may get away with a straight swop,otherwise it is re-format time.
The other issue you may encounter if using xp or vista is that if the new mobo is from a different manufacturer you will probably have to reactivate.
Good luck:)
99 times out of a hundred you have to re-install, but you shouldn't need to re-format.
So very true,however if you go for a reformat you will purge the system and once you gone through the drag of re-installing all your apps you should hopefully have a shiny new fast pc again.
Cheers fella's :headbang:
If you run sysprep (an MS tool) it will leave your data as is, but will reinstall all the required drivers for your system :)
HTH
