Self Service
My 53 plate Octavia vRS has done around 76000 miles and is due its fourth variable service in a 1000 miles according to the service indicator on the dash.
I am considering servicing the vehicle myself but have a few minor concerns that you might be able to help me with.
1. I would like to retain the full variable service schedule but understand that I would have to get the dealer to reset the service indicator. If I was to purchase the VAGCOM cable and software would I be able to reset this myself?
2. If yes to question 1, which cable and software do I need and where do I get it from and how easy is it to use?
3. Do any of you have a favourite supplier for service parts? GSF, AVS or other?
4. Any tricky stuff I should leave to the dealer?
Apart from the normal service I am also considering replacing brake discs and pads all round if they need it. I will however get the dealer or specialist to tackel the cambelt and waterpump before its 4 years old.
Thanks in advance.
1. Vag Com only reset for Variable, Im sure a local Briskoian with a Vag com could do it for you.
2. If you want to buy: Ross-Tech: Home is the manufacturer
3. i would say most parts could be purchased from GSF, etc. Or a skoda dealer would garantee you the correct parts.
4. Brakes are easy, i used this to do all of mine, discs & pads.
Brake pad and rotor replacement - Passat World Forums
You will need a piston wind back tool for the rears.
Hope this helps.
