Fabia Boot Size
Strange question I know, but.... can anyone confirm or deny that all fabias have exactly the same shaped boot space please?
May have to resort to tape measures, but was hoping someone might happen to definitely know already... :)
.... suck!
But then I never bought a Fabia for its boot, then filled it third full with sub :rolleyes:
Dunno about measurements. I'm 99% certain they're common across the (hatchback) range. :D
Sorry for the sarcastic reply but... the hatch, combi and saloon are all different.
However, if it helps all of the Fab hatches I've seen have looked identical, as have the Saloons, but the Combi's vary depending upon whether they have the side cubbies or not (Comfort and above).
Hmmmm, good point. Let me rephrase my question:
"Do all hatchback fabias have the same boot layout/size?" :)
Hmmmm' date=' good point. Let me rephrase my question:
"Do all hatchback fabias have the same boot layout/size?" :)[/quote']
It could be possible that the vRS has a slightly higher boot floor, to make space for the full size 16" spare...
but the shape should be the same.
It could be possible that the vRS has a slightly higher boot floor' date=' to make space for the full size 16" spare...
but the shape should be the same.[/quote']
The boot space specs are the same size IIRC, so the spare wheel hole is the same size as the other models or has a deeper hole, so to answer your question, they are the same size i.e a bit too small for a booze cruise.
Yet another good reason for me buying the Octy :rofl:
What im trying to say.. is the Honda Civic R has a higher boot floor because the wider than usual spare takes up more space.
with you now colin.
:( although as I live a lot nearer it means I can go over more often :P
