hello noobie joined
hello everybody,
I'm after a bit of advice. i'm thinking of purchasing a fabia vrs and was wondering are there any main concerns to look out for?
Also this may sound stupid but looking at the spec of a vrs on parkers.co.uk it says that the vrs has only a 2 speed wiper? is this true?
thanks
neil
Hi there and welcome to the site.
If you do a search for this you'll find a whole host of results. :)
Door leaks and clunking suspension are the main ones.
Hello and welcome.
The vRS is a great car and now it has ceased production has become sought after.
The wipers are two speed plus variable intermittant IIRC.
Check the rear floor for dampness is a hot topic at the moment.
Also the usual well looked after and full history is a must.
yup - the wipers have two speed plus variable intermittent which has four different time settings.
vRS is a great car. I've only have mine 6 weeks and have two probs. 1 is the wipers juddering. 2 The gearstick/box/linkage rattles when it idles in neutral - v annoying but to be sorted when it goes in for its 10k service.
If u get one u won't regret it.
Mark
Welcome to Briskoda
I've seen the new fix for the rattling gear lever - It looked a little agricultural.
hello everybody,
thanks
neil
How many speeds do you need ? :D
As mentioned the search is your friend and yes there are only two speeds plus a variable intermittant setting
