Autonostics cable problems
Just bought a USB-OBD2 interface off E-bay, and have downloaded the shareware version of VAG-Com and also ScanTool. Problem is, although the interface is set up OK on COM2, neither program sees the interface.
Daft question - is the interface powered from the OBD port, so has it to be plugged in to the car before it's recognised? :(:(:(
Could it be because it should be set on USB and not COM2?
And to answer the second question : No it does not have to be plugged in the car.
I have set up a USB-Serial port which is COM2.
If you mean that your laptop does not have a USB port and you are thus using a Serial - USB converter setup on Com2, then check para.1.5 of the following link:
Ross-Tech: VAG-COM: FAQ Page 1
If it says: port ok
interface not found .yes it does need to be plugged in.
I also use one of these cables,they work very well.
If it says: port ok
Yep, working now with VAG-COM :thumbup::thumbup: Needed plugged into the OBD port.
Still not working with ScanTool - it doesn't see the interface. :(:(
aye? fancy meeting up and plugging me in ? :P
Next time you come to tesco's gimme a shout ;)
I've never tried scan tool because vag-com is by far the best.
Have fun
Will do, Derek :thumbup::thumbup:
