Linux web server
I need a bit of help from anyone with experience in settings up a linux web server running ISPconfig and phplist.
My problem may not be related to those, but im at a loss!!
Deleted
I followed the instructions below..
The Perfect Setup - CentOS 5.0 (32-bit) | HowtoForge - Linux Howtos and Tutorials
everything is working great ISPconfig all works fine.
I then installed phplist under a no-ip.com domain, i then configured phplist to use a smtp server at the office. so phplist is hosted at domain1.no-ip.org on my home dsl connection and sends to mail.domain2.com. The problem i have is phplist (my server) will not send email to anyone outside of domain2.
So it will send to [email protected] but wont send to [email protected]. It also does the same if i configure it to use my ISP's smtp.
I have a feeling it is something to do with postfix or DNS but i dont know what im doing. I can post a bit from the postfix mail log that i think may shed some light on the situation.
Deleted
Deleted
Jul 16 18:55:51 server sendmail[4710]: l6GHtpXe004710: from=apache, size=7446, class=-60, nrcpts=1, msgid=<[email protected]>, relay=apache@localhost
Jul 16 18:55:51 server postfix/smtpd[4711]: connect from server[127.0.0.1]
Jul 16 18:55:51 server postfix/smtpd[4711]: setting up TLS connection from server[127.0.0.1]
Jul 16 18:55:51 server postfix/smtpd[4711]: TLS connection established from server[127.0.0.1]: TLSv1 with cipher DHE-RSA-AES256-SHA (256/256 bits)
Jul 16 18:55:51 server sendmail[4710]: STARTTLS=client, relay=[127.0.0.1], version=TLSv1/SSLv3, verify=FAIL, cipher=DHE-RSA-AES256-SHA, bits=256/256
Jul 16 18:55:51 server postfix/smtpd[4711]: 76EF62F8712: client=server[127.0.0.1], [email protected]
Jul 16 18:55:51 server postfix/cleanup[4714]: 76EF62F8712: message-id=<[email protected]>
Jul 16 18:55:51 server postfix/qmgr[2793]: 76EF62F8712: from=, size=8103, nrcpt=1 (queue active)
Jul 16 18:55:51 server sendmail[4710]: l6GHtpXe004710: [email protected], ctladdr=apache (48/48), delay=00:00:00, xdelay=00:00:00, mailer=relay, pri=145446, relay=[127.0.0.1] [127.0.0.1], dsn=2.0.0, stat=Sent (Ok: queued as 76EF62F8712)
Jul 16 18:55:51 server postfix/smtpd[4711]: disconnect from server[127.0.0.1]
Jul 16 18:55:51 server sendmail[4716]: l6GHtpYQ004716: from=apache, size=1019, class=-60, nrcpts=1, msgid=<[email protected]>, relay=apache@localhost
Jul 16 18:55:51 server sendmail[4716]: STARTTLS=client, relay=[127.0.0.1], version=TLSv1/SSLv3, verify=FAIL, cipher=DHE-RSA-AES256-SHA, bits=256/256
Jul 16 18:55:51 server postfix/smtpd[4711]: A39182F8713: client=server[127.0.0.1], [email protected]
Jul 16 18:55:51 server postfix/cleanup[4714]: A39182F8713: message-id=<[email protected]>
Jul 16 18:55:51 server postfix/qmgr[2793]: A39182F8713: from=, size=1565, nrcpt=1 (queue active)
Jul 16 18:55:51 server sendmail[4716]: l6GHtpYQ004716: [email protected], ctladdr=apache (48/48), delay=00:00:00, xdelay=00:00:00, mailer=relay, pri=139019, relay=[127.0.0.1] [127.0.0.1], dsn=2.0.0, stat=Sent (Ok: queued as A39182F8713)
Jul 16 18:55:52 server postfix/smtp[4715]: certificate verification failed for pinnz.co.uk: num=18:self signed certificate
Jul 16 18:55:52 server postfix/smtp[4717]: certificate verification failed for pinnz.co.uk: num=18:self signed certificate
Jul 16 18:55:52 server postfix/smtp[4715]: 76EF62F8712: to=, relay=pinnz.co.uk[74.52.227.18]:25, delay=1.5, delays=0.06/0.03/0.96/0.43, dsn=5.0.0, status=bounced (host pinnz.co.uk[74.52.227.18] said: 550-Verification failed for 550-unrouteable mail domain "server.localdomain" 550 Sender verify failed (in reply to RCPT TO command))
Jul 16 18:55:53 server postfix/smtp[4717]: A39182F8713: to=, relay=pinnz.co.uk[74.52.227.18]:25, delay=1.3, delays=0.05/0.02/0.92/0.36, dsn=5.0.0, status=bounced (host pinnz.co.uk[74.52.227.18] said: 550-Verification failed for 550-unrouteable mail domain "server.localdomain" 550 Sender verify failed (in reply to RCPT TO command))
Jul 16 18:55:53 server postfix/cleanup[4714]: 3164D2F8716: message-id=<[email protected]>
Jul 16 18:55:53 server postfix/qmgr[2793]: 3164D2F8716: from=<>, size=10192, nrcpt=1 (queue active)
Jul 16 18:55:53 server postfix/bounce[4721]: 76EF62F8712: sender non-delivery notification: 3164D2F8716
Jul 16 18:55:53 server postfix/qmgr[2793]: 76EF62F8712: removed
Jul 16 18:55:53 server postfix/local[4722]: 3164D2F8716: to=, orig_to=, relay=local, delay=0.02, delays=0.01/0.01/0/0.01, dsn=2.0.0, status=sent (delivered to maildir)
Jul 16 18:55:53 server postfix/qmgr[2793]: 3164D2F8716: removed
Jul 16 18:55:53 server postfix/cleanup[4714]: 415F82F8712: message-id=<[email protected]>
Jul 16 18:55:53 server postfix/bounce[4721]: A39182F8713: sender non-delivery notification: 415F82F8712
Jul 16 18:55:53 server postfix/qmgr[2793]: 415F82F8712: from=<>, size=3654, nrcpt=1 (queue active)
Jul 16 18:55:53 server postfix/qmgr[2793]: A39182F8713: removed
Jul 16 18:55:53 server postfix/local[4722]: 415F82F8712: to=, orig_to=, relay=local, delay=0.01, delays=0.01/0/0/0, dsn=2.0.0, status=sent (delivered to maildir)
Jul 16 18:55:53 server postfix/qmgr[2793]: 415F82F8712: removed
make any sense to you??
from what i can make out the mail server is rejecting my servers connection..
Deleted
# Do not remove the following line, or various programs
# that require network functionality will fail.
192.168.0.2 server server.example.com
127.0.0.1 localhost.localdomain localhost
::1 localhost6.localdomain6 localhost6
i thought this would be the problem, but i dont know what should be in there..
Deleted
i have a no-ip.org domain, will that not do?
Would my hosts file have to be edited for every domain i host on the server?
ie
192.168.0.2 domain1.no-ip.org
192.168.0.2 domain2.no-ip.org
Brilliant.. its working!
Thank you auroan!!!!!!!!
Amazing, it now sends to most domains except hotmail who reject it and the domain its supposed to be sending from.. sort of reversed the problem lol
Deleted
yep.. i changed the hosts file so that it looks like this..
192.168.0.2 domain.no-ip.org
and it worked, but as i said it no longer sends to the same domain lol
Deleted
what would you have changed it to?
Deleted
