Switched 12v supply in Octy II?
I'm fitting a hands free car kit in my Octy II and need a ground , permanent 12v and switched 12v.
The first two are simple enough - the light for the glovebox has these - but the latter is not so simple. The cigarette lighter has a 12v feed but I can't get at it.
Is there anywhere handy near the glovebox?
You may need to run a wire over to the fuse box, I think the fuses down the left hand side are 12v switched (terminal 15).
Fusebox fuse nr 9 and the next ones in the same row are 12v switched.
Climatronic, right connector grey/black lead.
Thanks , for that , both of you.
Looks like I'll be playing with the fusebox tomorrow.
I'm sure I crimped on the connectors for the Fuse Box Alex.
There ought to be one marked phone which is switched.
You could run a wire from the climate controls power too if fitted, thats a switched connection iirc.
I've just fitted a CK3100 Parrot kit into mine a few days ago, I too found this problem right at the end just before it got dark, half an hour later after realizing that there simply is NO 12v Switched I had to run it to the fuse box.
Just a word of advice, if you are using the kit through the car audio speakers - hiding the cables etc behind the head unit isn't that easy - there is very limited space behind there expecially when you are using the ISO/Mute ext' blocks!
Wilko
Alex doesn't have any ISO/Mute leads.
A tip if you are struggling with the rear cabling is to lift out the top stowage and you then have access to guide the cabling into place.
I did think about that but thought it looked a little tight with the air vents.
Oh well....
Wilko
great tip - wish I'd known that a few weeks back when I was "redoing" my Parrot,after Hal****s wired it to a permenant live!!!!!!!!!!!!!!!
I got my switched live from the climate panel when fitting my parrott 3200. As for the wiring, i managed to stow it all behind the ashtray towards the bulkhead.
Hi there,
I just gave up trying to cramp a Iso2car mute cable + IGNI Box (which creates a 12v switched without wiring to the fuse box). There simply is no room left behind my STREAM radio.
Is the answer to stowe it away behind the ashtray ?
