312mm upgrade - squeakyness?
Anyone done the 312mm upgrade with G88 Discs and Mintex Extreme pads and suffered from lots of brake squeal? (my mate has a Golf MkVI Anni and suffers massive squeal from brakes with same setup most of time)...
also anyone found a solution/treatment to corrosion on G88 Discs prior to fitting (around where wheel hub makes contact with disc)?
am due to fit these next weekend so any advice would be great!!!
Mintex Extremes do make a bit of noise.
Grease them during install with copper slip. This will also work for the hubs
