a TDI tuning box......
Hi i recently installed one of these boxes on my vRS, but i realised that my engine is now juddering alot more, but i don't know why this is, any ideas? but i have felt a performance gain since istalling it though....
It could be that you need to drive around the DMF issue...
Flywheel is my bet too. If you take the box off does the juddering go away?
If so then you may not have damaged it. Otherwise it may be buggered.
umm.....what is DMF? and what issue is this? i don't understand sorry :P
and yes the juddering does go when put it back to standard, so what does this tell me then? that installing and buying this box was a total waste of time then?
Dual Mass Flywheel - two rings connected by springs (basically) to damp down the vibrations.
firstly , when does the juddering occur ? low revs when you boot it ?
it occurs whilst idling doesnt idle smoothly.....the whole car like judders more than usual, you can real feel it judder badly
Sounds like you're OK then (regarding DMF). Just idle speed that has been affected - mine is lumpy at times whilst idling, switching AirCon in / out, heated rear window etc affects it.
The DMF problem most of us are referring to is when you boot it in too high a gear at 1500 to 2000 rpm.
what box is it?
i bought it from ebay, think its something dragon box, something like that...
have you tried turning it down?
I know its been covered before, but these boxes only over fuel the engine to gain performance, and this fuelling is not accurately measured.
A re-map is much better for the engine and other mechanical parts.
As mentioned above, you may need to turn the variable resistor down to reduce fuelling, however you will loose performance also.
If you dont have an adjuster, and the box you have got is ''L'' shaped, then all it has is a 2p resistor inside.
I have had this problem with a generic remap that a local garage put on the ecu.
Sorted it by replacing the ecu under warranty. Now have an Angel Tuning map on the car and have had no problems since.
Hi There
Did they de-solder the chip and damage it?
It should be a flashed re-map via the OBD port, in which case, software alone cannot write an ECU off.
I'm guessing they physically damaged with poor equipment:(
Hi iv also got a dragon tunning box on my fabia vrs, had it on a few months now done about 3 thousand miles with it on full power, didnt notice much improvement untill i turned it on full.
It has made a difference once turned to full power but the other day i noticed a judder when i was parked up with the engine on but it seems to be fine whilst on the move apart from the extra black smoke!!
My girlfriend has also got a fabia vrs (standard) and she has never noticed a judder could this be the tunning box? Seems strange me and channy have noticed the same problem!!!
Mine was a little rougher at idle too. But nothing that bothered me to be honest. The 318lbs ft of torque made up for that.
Any experiences of the Van Aaken smart boxes out there?
my Dragon box equipped VRS is sometimes lumpy on tickover , but then even standard it was like that , so not that bothered ,
Paulk22 , the box does take a bit before you feel the benefit , mines still on the standard 11 setting and its noticibly more pokey (and sooty) than it was without the box , might try it up a setting soon
Some of the Dragon boxes (I know the Ford TDCI ones do) can be connected to use their inbuilt delay circuit which means the tuning box won't be activated until x minutes after the ignition is turned on (I guess until the car is up to temperature) which can get round lumpy idle issues when cold....
Chris
When i purchased my dragon tunning box i was told it would have this delayed feature on it, extra safty precaution i guess.
But still get this juddering? Hope its nothing to worry about!!
I had a little fling with one of these and I got the problems mentioned above when booting it 1500 - 2000 rpm. I didn't really want to have to drive round it so I sent it back under their 30 day warranty, full refund!
Like the other posts say, remap is the way to go.
If the problem disappears without the box fitted then leave it off and sell it on, is it really worth buggering up the DMF?
  • 11 months later...
If its not adjustable then take it off and get on that is or just by the trim pot from somewhere like Maplins and make your own.
The reason it runs like a bag of poo is that its getting too much fuel on idle , if your box is not adjustable then the resisor that is in it is of a too high value thats why it best IF your going to use on of these to use a varible one like a trim pot.
I found that on my 110 Octy that the resisance was about 4.7 ohm
I reckon it's sorted now, 12 months since the last post! :D
Opps didnt notice lol
