Octavia 1.6 LX in distress
Can anybody suggest a cause with this list of symptoms?
The engine of my 2000(X) Octavia 1.6LX has cut out twice in recent weeks at low revs (very wet conditions on both occasions) and subsequently refuses to re-start. The fault clears after a period of time (first incident about an hour, second incident several hours). There was no indication of fault from ECU or immobiliser (don
I had a similar set of symptoms and it was diagnosed as the "crank position sensor". The cutting out became progressively worse, and when it did start then it would rev randomly...
Rob.
similar to one we had a faulty distributor
Could probably do with a throttle body clean and maybe a new coolant temperature sensor.
iirc this engine does not have a crank sensor, it has a cam sensor instead.. sometimes a little oil leaks past the o-ring on the back of the camshaft ans plays havoc with the sensor
