Battery flat when wet
Last month:
  • Battery flat when I finished work
  • Got a jump start from friendly colleague
  • drove home (28 miles)
  • Car drove fine
  • Car started next morning no problem - battery holding charge
  • I suspected the problem to be a faulty PDA charger plugged into the cigarette lighter (no lights were on, or other driver aids)
Yesterday
  • Battery flat again when I finished work
  • Got another jump start
  • drove home
  • Car drove fine
  • Car started today no problem
  • I now suspect something else, perhaps the battery, alternator (no lights were on, only thing that came on after jump start was the windscreen wipers, which I left on the slowest setting)
What do you guys think?
Martin
this happend to me. had just enough power in the battery to star it once.
I took it to th local dealer for them to check, where they replaced it under warrenty.
Being that I qualify as friendly colleague, I'll chuck in my comments to help get the ball rolling. This only seems to happen when wet, and therefore I am thinking that it could some form of short somewhere. However as I don't own a fabia I am not aware if they have any particular water ingress issues that could cause such a problem.
Personally I doubt the battery is at fault, as the occurances between faults must have been at least a month, and the car has started perfectly in the meantime with no obvious signs of battery failure....
Just driving 28 miles is not enough to recharge a flat battery...........
you either need to charge it on a battery charger or go for much longer
drive ........ I read many moons ago that it takes about 20 miles just to
put back 1 start up .......... so when you take other things using the battery like radio / wipers / heater etc
Last month:
  • Car drove fine
Yesterday
  • drove home
  • Car drove fine
Martin
You're not the new Leicester City Manager are you? If you are SORT IT OUT NOW!
If not, i apologise.
Charging the lead-acid battery
This seems to be a nice description of the stages of battery charges and seems to indicate that 3 hours of charge would get it to 70%
Martin
I'm not *the* Martin Allen, however I did have a sticker of the man himself on my pencil case when I was at School (when he was playing for West Ham).....
Sad I know :-)
Martin
Sad I know :-)
Martin
Oh well, never mind! just thought for one glorious moment i could put my suggestions for improving the World's greatest team to the man himself....
