OIL Change light
This is for my fabia vRS. When i turn my engine on a OIL wordis displayed in the speedometer, i have looked in my book and this is a oil change requirement. I was just wondering if anybody knows how to erase the oil change light for everytime i start up. This goes of after 3 minutes of driving.
Many Thanks
Dave
The simple answer is if the service is due then have the service carried out.
If the service isn't due then there are instructions in your manual on how to clear it.
The service isnt due yet, i will have to look in the manual then, not that i could see anything before
You will find instructions on how to reset the service interval on the opposite page to that which tells you what the OIL warning indicates, ie on page 17. When did you car last have an oil change?
press the reset button for a second and light goes off but will come on every time yous tart. There are ways to turn it off as above in handbook.your inspection serice will be on soon tho get both done together
I've got the same warning come up but I only had my service carried out within the last 4000 miles and the oil is at the top marker on the dipstick. The thing is it wasn't there until after I fitted my FMIC. Could it be something that was done wrong to make this come on straight after we finished putting it all back together? I had a mate VAG COM the car but it doesn't show up with anything either.
It seems common for the service warning - OIL then spanner - to come up at odd times and is just a nuisance. Mine has done it from new. It will continue until you rest it and then be OK for thousands of miles. Just follow the sequence above. Note that this is not the oil level/pressure warning light which is to be taken seriously.
I've got a Saab (for the weekend) on the drive with 2500 miles on it, brand new.
It is doing the same thing 'time for service warning' yet the car is only a couple of months old (judging by the tax disc)
wierd.
I've tried what the manual said and still no luck, the spanner still remains on the display and the OIL warning still flashes when I start the car. All its done is reset my trip counter every time I've tried it. It says press the reset button next to the display which I did for 2 minutes with the ignition switched off and with it switched on and there's no difference. Any other ideas?
OK, switch off the ignition and remove the key, hold down the trip meter reset and continue to hold while you put the key back in and turn on ignition but not staring the car....After approx 10 seconds the OIL and Spanner will dissapear.
Hope this helps
Will give it a go thanks mate
That worked a treat thanks.
The reason the service light can come up before the milage is actually due is because most modern cars have a sensor which checks on oil quality so if the car thinks that its oil is dirty before the due milage it will start shouting at you for an oil change. To reset switch off ignition and press reset **** of trip computer and hold in. Switch on ignition and release reset button and one of the service events will come up (oil service or inspection service). Switch between the readouts by briefly pressing the reset button. When you are on the one you want (oil or inspection) turn the button for the clock to the right abd service --- will display. Switch off the ignition and it will be reset.
Steve
Steve
