VAG-COM setup problem
?I thought I'd buy a cheap cable and give it a go with the demo version before comitting to the full version.
Got a straight USB<>OBD2 cable and the drivers,
Loaded them in to the laptop and also 409.1 For the TWIN-USB Interface from ross tech (My problem maybe)
Plugged into the car, and on initial setup it wont recognise on either the USB or any of the Serial ports?
Any ideas, The cable is detected by the laptop and the LED lights up when plugged into OBD port, just no connectivity?
It was late last night so didnt persivere(sp) just thought i'd ask before getting stuck in again tonight.
Check that you have the correct driver installed - there are a few. Should work fine then.....
HTH
Bas
Have you installed the usb-serial driver that came with the cable?
Yep all drivers installed, I didnt have my car for the last 2 days so not had a chance to mess about, i will give it a go tonight, thought it was maybe the wrong version of VAGCOM I was using as i couldnt see a usb specific one, only twin usb :confused:
I got it working, my USB cable was set to com port 9, changed it to two and bobs yer mothers brother!
