Knackered bolt hole thread trying stutter fix.
Typical. I mean how hard can it be to remove and then replace 2 bolts? I've managed to knacker the thread on the hole putting the bolt back in. No way was it going in. It would turn so far then stop. So I thought 'if I can just get past this stiff bit.......'. You know the rest!
Anyway, will an ordinary nut and bolt be ok in its place? Or does the existing bolt form a seal?
Help!
Derek
Deleted by MODVRS
Edited by MODVRS
the gas seal is formed by the "bump" in the metal gasket, I think.
correct , and if you can get a nut and bolt on the pipe that should be ok , if not ideal :rolleyes:
Drama over! Uncle advised me to thread bolt in from other side to 'repair' the thread. It worked andd bolt now in.
And I can confirm that the stutter has completely gone now (50 miles later).
Thanks all
