Help with faults
:confused: Hi Guys
Can someone recommend what to do with these codes. I'm suspecting a vacuum hose leak and poss MAF. I've never done any auto D.I.Y. but don't want to get ripped by the "stealership".
Car = Octavia elegance 4 x 4 1.8T
Here are some codes
VAG-COM Version: Release 409.1-S
Chassis Type: 1U - Skoda Octavia
Scan: 01,02,03,08,15,17,19,35,46,56
Address 01: Engine
Controller: 06A 906 032 HJ
Component: 1.8L R4/5VT 0002
Coding: 10700
Shop #: WSC 31480
TMBSL21UX28540845 SKZ7Z0A1023982
3 Faults Found:
17544 - Fuel Trim: Bank 1 (Add): System too Lean
P1136 - 35-00 - -
17608 - Boost Pressure Control Valve (N249): Mechanical Malfunction
P1200 - 35-00 - -
17705 - Pressure Drop between Turbo and Throttle Valve (check D.V.!)
P1297 - 35-10 - - - Intermittent
Readiness: 0000 1001
Address 03: ABS Brakes
Controller: 1C0 907 379 F
Component: ESP ALLRAD MK60 0104
Coding: 0023174
Shop #: WSC 31480
No fault code found.
Address 08: Auto HVAC
Controller: 1U1 907 044 A
Component: CLIMATRONIC C 2.0.0
Coding: 01000
Shop #: WSC 31480
Skipping Address 15-Airbags
Address 17: Instruments
Controller: 1U0 920 911 B
Component: KOMBI+WEGFAHRSP VDO V03
Coding: 23412
Shop #: WSC 07893
Address 19: CAN Gateway
Controller: 6N0 909 901
Component: Gateway K<->CAN 0001
Coding: 00006
Shop #: WSC 31480
Address 46: Central Conv.
Controller: 1C0 959 799 B
Component: 3Y Komfortger
Phil
I have moved your thread to the appropriate forum for the questions.
If you search for those codes you'll find no end of information about the causes and fixes for them.
I think this is a cross-post. I've already replied to the original, here.
