Sun roof adjustments
Hi All
Has anyone got experience of the factory fitted electrically operated sun roofs.
Mine has gone faulty. I have taken it apart and ordered the parts which had broken.
When I put the roof back together, what is the correct position for the opening glass?
Should it be flat and flush with the outside roof, or should it be lower at the front (about 1mm) and proud at the back by about 1 mm?
Also any tips on getting the screws back which hold the glass roof back and tight.
Any help on the above will be much apreciated.
Dougal
Should be flat when closed
