A few questions!
Hi all,i'm fairly new to this section i'm normally in the Fabia section as i have a vRS, i've just bought an Octavia 1.6 GLXI as a second car and i have a few little things i need to sort out hopefully with a little help from you more experienced owners!
Firstly the Central locking doesn't work when operated anywhere other than the boot, i have removed the locks from the doors and when you turn the key in them the blade that slides in to the actuator doesn't turn with it! is this a common fault?
Also the Radiator fan doesn't work! are the fan switches bad for going on them? And the electric mirrors don't work, i've checked the fuses which appear to be ok and the controler is plugged in ok!
Other than a full service to smooth the running of the car out these are my only issues.
Can anyone shed any light? i hope so!
