felicia door lock swap help
I have a knackered door lock on drivers side Felicia 1.3, 2000. It spins on itself and does not operate centrla locking. On inspection inside panel the lock barrel part is not turning the arm connected to it and thus operating the locking system.
Can I borrow the lock from the passenger side or are they one sided ?
Otherwise I am going to end up with 3 keys coz I'm too tight to have new lock matched to old key.
Ian
They are not handed, why not get a new lock and take the good bit off it to replace the broken bit on your lock and you won't have a different key.
Don't know which part of barrel is broke and can't be assed to take it apart.
if you dont take it apart or get a new barrel cut you ain't gonna have much in the way of locking for youur door mate...
You'll be able to see it, it's held on by a circlip
Fixed the door lock yesterday, new lock, job done after a few scraped knuckles. Locks are one sided as the arm is attached, if anyone has same problem. Now I don't have to unlock from passenger anymore - hurrah. £23 all in but that was for lock with different key.
