Maxi Dot
Silly question i know , but can maxi dot be fitted afterwards ? got a 07 reg octy Vrs Tdi and wish i had it fitted now
skoda themselves say no but i believe it can be done but is quite expensive
Contact the Stu-meister for further details...as it can be done! :)
Thanks for the replys folks
Yes stu can get them pretty cheap compared to skoda's prices.
I did mine afterwards. You don't get all the functionality of the convenience settings (do a search!) though - or at least we haven't worked out yet how to get this enabled!
There are a couple of others that have retro fitted maxi-dot.
I think the level of options available on the Maxidot retrofit may be car specific - Newer cars = more functions
Probably totally right Stu as my car is fairly much poverty spec, but I'd have thought the alarm stuff would have been there (..and its a 2008 model!). Still, I'm very happy that I fitted the maxi-dot as the main thing is it looks a lot better, clearer and it works with the Bluetooth perfectly and as you said, you cn easily plug in vag-com to chaneg the other bits!!:thumbup:
Just to revive this thread. I'm getting my Scout on friday.
What do I actually need to buy to retro fit maxi dot ? and what's involved in coding it to the car.
I have a full registered HEX-USB+CAN Interface Vagcom cable, which I'm comfortable using. just need the actual instructions on what need adapting etc.
You need a dashpod and to have the immobilisor coded at a dealer. With the dashpod make sure to get the 4 digit SKC although they can be generated it's easier if you have them.
If you get a used dash then these can be coded with VAG-COM but for some reason I've not been able to get a new one to work.
oh bum. I'd rather get a new pod.... but if it means a dealer visit, then it might not be worth the cost.
send a PM to VRstu, he gave me a price (pretty good one at that). But not sure whether or not to go with it yet! Well I don't actually have the car yet so not even able to make that decision!!!!!
Send a message and see what he can do. I would certainly rather drive my car to Stu than to a dealer! He seems very knowledgable and has a lot of happ clients on here too!
Stu, Thanks again for the offers, I will let you know about when and if I want to take you up on them. :thumbup:
