Overfilled oil
The service indicator on the dashboard showed the word 'OIL' yesterday, and as I had noticed a few spots of oil under the car over the past few weeks, I presumed that it was running low. Unfortunately, I was in the middle of nowhere and by the time I got to a garage to buy some oil the EPC light was on. I added the oil, but I have overfilled it by about a cm. The EPC light did not come on again.
Anyway, I'm going to take it to the garage which is about 1 mile away. Will it be okay to drive it this short distance?
Sorry, What are you going to the garage for? Because you want to drain a 1cm of oil?
Surely 1cm will be fine,
either that or do it yourself. sump plug out, etc
Good excuse for an oil change
1 cm isn't even worth worrying about. And any decent garage should be able to tell you this.
Ok. Thanks for that, I really know nothing of these things and just presumed that anything over the top end of the indent on the dipstick might cause damage. Glad to know that this shouldn't be the case.
No, no problems at all.
Welcome to Briskoda!
it will soon disappear if you decide to take it out and play with the gears ;)
