Oil change
Hi all,
Just had my oil and filter changed at national tyres for £30.
Although an excellent price they used Castrol EDGE 5w-30.This is a long life oil but i only plan on changing every 10000 miles.
I presume it will be fine but would fully synthetic have been better as thats what i asked for.:confused:
I thought that was fully synthetic
So fully synthetic and long life? best of both worlds then.
I'm a happy bunny now.
I'm pretty sure all Longlife oils that VAG recommend are fully synth.
run that oil in passat 130 4 motion for four years no prob at all , use this oil daily at work
Grrr the monkeys have overfilled by about 0.5cm,will car be ok or shall i take some out?
p.s my car doesn't use oil so it will be there until next service
It will be fine.
Cheers Ross,that puts my mind at rest.
Mart
Are you sure its OK to use 5W/30 in a 1.8T ????
Would have thought the min spec would have been 5W/40 in a turbo (petrol) engine.
I use 0W/40 Mobile 1 SHC in mine, its changed anually @ less than 2.5k usually.
bill.
Yep, its on the castrol site ("what oil should i use") recommended for the octy rs Motor Oil and Lubricants Castrol UK - Lubricants
Interestingly recommended for both the QG1 and QG2 service schedule.
