heya
alrite every body??!! im a new user and i have just joined.
this is my very first post - ever...lol!!
my uncle has just bought a BMW 323ci (traitor) and i have been given his old 2000 fabia 1.4 8v and it is revving very highly in all gears. the revs are also raising and dropping constantly - even in fifth between 2000 and 3500 rpm. also the timing chain needs changed as it is rattling. i have been told this is the clutch slipping!!?? does this sound right??
i have been quoted £165 in vat+labour for the clutch by a local garage here in Northern Ireland.
i have also been quoted around £100 for the changing of the timing chain.
do these prices sound resonable?
your replies are appreciated.
Hello and welcome to Briskoda
Havent a clue about your probs sorry but im sure someone will be along soon to help
Carl :thumbup:
im shocked some body replied so quick!!
you guys are on the ball!! lmao!
as i said i appreciate your time any way
thanks again
hello
howzit goin m8!!
do you know much about the 1.4 8v fabia??
the one i am accquiring also has a strong smell of rotten eggs cumin through the heater when both hot and cold air is being blown through
Hiya.
Your original described symptoms do sound pretty much like a worn clutch and timing chain, and the prices to replace aren't too bad.
As to the rotten eggs smell, try some fuel from a different garage to your usual, in case it's as simple as you having a batch of high sulphur fuel, before doing anything that costs money.
thx m8!
i have been told there is a water leak coming through into the heating system and that the water has gone stale - hence the smell!
thanx for your help ken and i shall endevour to try your idea before i try getting it drained.
Is any body aware of a place that i could find CHEAP parts for my little 1.4 8v fabia??
both mechanical and styling parts.
thanks.
I don't know where they are on the Fabia, but there are usually some heater drains which can get blocked up with leaf mould and the like. They can be cleaned with a stiffish piece of copper wire if that's the problem.
Join Freedom for 10% discount at GSF, and site search Butts of Bawtry for a useful weblink on cheap parts.
Howya, you have a PM
