Tech help required....
i need to tap into the lambda sensor for my air/fuel ratio meter.....
which wire should i be using?
also looking for a good place to drill into the system for an oil temp gauge?
suggestions welcome... pref useful ones....:rofl:
I think DaveU is doing this one......a new sump plug drilled to fit sensor....
Yep - for oil temp get a new sump plug and get it drilled out to house the oil temp sensor. Plug sits on the back of the sump so should be OK.
I'll be doing mine in the next week or two.
cheers
anyone got a clue on the lambda?
which lambda probe are you hoping to pipe into. broadband type pre cat or planner type post cat.
does make a differance to your readings.
cheers
From previous playing:
WHITE: HEATER
BLACK: SIGNAL
GREY: EARTH
On three wire sensors you will have one of each, on four wire there will be two heater wires. Not sure what is on the Skoda.....but on the FIAT, 4 wires were present and was able to observe the signal on the BLK wire and earthing to the exhaust using an oscilloscope. Again...not sure of what is on the Skoda....so be careful, no responibility taken blah blah, covering own back etc!!!! :D
Hope that helps!!!
/Gavin
This site has some info. The Favorit, Felicia and Octavia 1.6 (no other engine sizes listed) all use the Universal 11984 as a replacement which ties in with Gavin's advice on wiring colours. Look at Wire Colours (1) if you want to get really confused by the various permutations of colours used by manufacturers!
mine has 5 wires?
i thought the one before?
but now im not sure?
Just take the cat out then it doesn't matter ;)
sorted FYI denis the 1.8T does use the same lambda :)
the site lists it under A4 and Passat ;)
thanks
Paul - be interested to know what the 5 wires are if you found out. Take it it's 5 on the pre-cat?
5 pre cat... 4 post.
