Favorit - where is the indicator flasher unit?
We have just inherited a Favorit (1995 'M'). Looks in good condition but no indicators or hazard lights! :confused:. In the absence of a Haynes manual (soon to be ordered), can anyone tell me the location in the relay/fuse tray of the indicator flasher unit? It is the prime suspect since the indicator stalk unit is new. The relays all look the same and are certainly not labelled. The user's manual lists fuses but not relays. Any help would be much appreciated in getting us on the road.
Regards,
Taff
The flasher unit is clipped in behind the push button switches, an old fashioned looking metal cylinder type.
Yep just undo the screw to the left of the intrument panel and it comes out. The hazards fuse is shared with the horn so if that doesn't work too it's probably the fuse in the fusebox.
