Running 205/50 on a vRS?
Just wondering if anyones had any experience running 205/50/16's on a Fabia vRS?
Been thinking on how you can improve the ride over rough roads without changing the springs/dampers.
So assuming same make of tyre is used
205/45 16 gives a rolling diameter 591mm
205/40 17 gives a rolling diameter 596mm 0.85% increase
215/40 17 gives a rolling diameter 604mm 2.2% increase
205/50 16 gives a rolling diameter 611mm 3.38% increase
Now I assume members use 215/40 17's to help improve the ride so thinking a profile change to 50 on the 16's could be an idea.
Any comments? Not planning on doing anything yet as all 4 tyres have plenty of tread left. Could get a cheap set of 205/55 16's inc alloy (bigger profile again :eek:) of ebay and see what they are like.
It will upset the speedo rating mate.
I've had 215/40 16 in the past which allso upsets the speedo, makes it overread. Not fussed about thye speedo.
why not buy my spare set of fabia vrs rims :D
They'd be just fine.
Not sure the improvement in ride comfort would even be noticeable though tbh. Just get some FSDs and be done with it! ;)
I reckon you can get away with 205/50 R16s :)
can the speedo not be re-calibrated?
Where's the fun in that. :)
I toyed with this idea myself about a year after I got the Furby and its tyres were getting a bit bald. IIRC, the overall increase in circumference is only about 3.5% over the 45s, so the speedo ought to be more-or-less spot on in fact, given it seems to under-read by about 3 to 5%, depending who you ask... :thumbup:
