Driveshaft 1.9SDi
Hi folks,
On the look out for a right side drive shaft is it a dealer part only? Tried a few local autostores + car breakers and it seems to be a rare part!
TIA.
Have you tried a motorfactors? Could also try Skospares.
Thanks for your help, I will get a chance later to have a good look at your suggestions, I did try a few motorspares...no joy though.
before I buy a new shaft..
I had replaced a boot kit on the same side a while back, shortly after this the dreaded cluncking started, a mechanic had a brief look at the shaft while replacing the antiroll bar and confirmed I needed a new shaft...although I was wondering is there a possibility that I have damaged something at the gearbox side or even in the gearbox, the shaft needed a bit of persuation get through the hole at the wheel end during replacement of the boot kit.
Thanks.
