change the bulb in right wind mirror
How do u get the bulb out?? I cant find any screws?
IIRC its a sealed unit so you have to buy whole indicator unit. You need to remove the glass to access the screws....might be better getting dealer to fit it (incase you break the glass).
The puddle light (if fitted) is a standard W5W bulb, you simply pop off the painted mirror housing and unscrew the fitting to access the bulb.
This is of course assuming the white puddle light has gone and not the orange indicator repeater which is indeed a sealed unit.
Grab the painted cover with both hands and pull upwards and slightly towards the rear of the car, make sure the mirror part is pointing downwards as this makes things easier. The covers just pop off and there are no screws etc.
This is what you'll find underneath:
HTH
