How do you get to the bulb?
Hi, I have a 55Reg Octy 2 Estate and the top bulb in the rear nearside light cluster has blown.
I can get the cubby hole cover and the small access cover off, but the top bulb seems to be in a seperate holder up behind the trim.
Do I need to remove any more trim, if so how and how does the lamp holder come out.
Many thanks for any help
Ta
Hi, just replaced mine last week. If I recall, remove the trim covered access panel, and you should be able to see the back of the one piece bulb holder its about 7/8 inches long. If you look roughly in the middle their is a plastic clip that you squeeze, and at same time pull back. The whole bulb holder will unclip from housing, if you slightly twist holder it will come out a little bit to reveal bulbs, or you can unclip the wiring connector to totally remove holder. Also, on the wiring connector their is also a lone separate wire which goes up towards the top of light housing, which also has a bulb on its own, which simply pushes into recess.
