Cage mod Question??
Went to Maplins to get the stuff but..............................I think I bought the wrong stuff!!!
Can anyone help me?? This is what I've bought.........
Thanks................:thumbup::thumbup:
Yes, thats the wrong stuff.
It should be Servisol Silicone grease, its in a 50g white tube, sorry not a spray, think its about £4
Thanks, Back to maplin I go!!!!
:thumbup:
That stuff will do it.
It's just a spray version and maplins own.
It is still silcone grease and they have added PTFE which is an awesome insulator. I'd say it's all good, put some on the MAF connector and then plug it all back together.
I had some silicon di-electric grease kicking around so tried it on a friends car. I feel a bit of an improvement with smoother coming on and off the power, but no improvement at all at idle.
My stuff is the servisol tube that you can buy in mapli/RS etc.
As such I'm still unconvinced, but time will tell.
My local Maplins have sold out of this stuff. There must be a purge on buying this:rolleyes:
I have the spray. When I do it I'm going to spray it into the can's lid, and then it won't be much different to having gunk out of a tube.
Just spray some onto the MAF connector on the cable side and then plug it on and don't worry about it IMHO.
anyone got the store code for this? :thumbup:
couldn't get it yesterday. :(
RE90X I think.......
Chris
This is the stuff most of us are using Maplin > Multi Purpose Silicone Grease, as Chris says, Maplin code is RE90X. It looks like this...
18027.attach
The aerosol stuff is essentially the same product but I don't know whether it will have the same (very stiff) viscosity as the above.
Its better to use the grease than the spray:
I actually totally filled the female part of the MAF connector with the stuff then you slowly push on the male part of the connector.
You will see the spare grease being forced out the top of the connector. This way you force out any air in the two parts and more importantly there is no movement between the two parts, allowing good consistent connection - aided by the silicone grease.
A small improvement in responsiveness is noticed but don't expect a lot.
Grease or spray won't make a huge difference as all it is doing is coating the connector.
Main advantage of the solid grease is that you can apply it once and pretty much forget about it as opposed to maybe giving the connector a spray once in a blue moon.
The spray however won't go hard and manky over time due to dust etc getting trapped in it. This will require effort to clean out. Using the spray means you don't end up with this and any possible issues it might cause.
At the end of the day it will make no difference what you use as long as it is a silicon dielectric grease in one form or the other. What the grease does is coat the connectors to prevent oxidation and where one connector makes contact with the other this will be broken off allowing connection. The grease will keep out moisure and prevent electrical leakage so in theory giving a better signal.
Other dielectric greases may well work fine too, but I haven't looked into any of them.
Yes thats the stuff
Cheers :D
A 50 gramme tube is only £4 at Maplins
If they've any in stock, And your lucky enough to have a Maplins near you.
Alternatively CPC do the Servisol for £3.34 but you need an account, And minimum order total of £40 to avoid postage. Gotta take the bad wiyh the good
I done a quick costing the other day to supply members and reconn about £4.55 delivered but I would have to get the OK from a Mod'
Anywhere who sell silicon grease should alright? It doesnt have to be just maplins!
