Not Warming up
Since I've had the Octy it's always done it's warm up process in the mornings but the last 3-4 times I've started it from cold in the morning this hasn't happened. It's been below freezing and still nothing.
Any Ideas? :confused:
Is this the pump that starts up for a minute, then dies off ?
i think so, sounds really weird then dies off after a min or so when first starts. I read the stuff on here before i go one so i know thats normal.
Strangely it did it this evening when i left work but didn't this morning when it was like -1 outside.
Does it mean the pump is on the way out? Also where is it, whats it called and how can i tell if it's on the way out?
Thanks in advance
I think it depends on the engine temprature.
I know if I use mine 1st thing in the morning, I hear the Pump, but then if i use it say about 1.00 i dont hear it.
If i park it at work at 8.00 then leave at 4.30 it does use the pump.
Depends on how long I leave the car undriven.
Hope that makes sense.
Yeah that's the same as mine, i think it went to do it this morning but then didn't.
Does anyone know where the pump is and what it's called?
I will give it a check this weekend when i get chance.
No one else got any ideas ?
Its the secondary air pump and tbh unless you find it embarrsing you will be fine
