Tyre pressure warning
The light is on my dashboard for the tyre pressure . . .have had 2 new tyres fitted since the light coming on . .it's still on!!
All 4 tyres have the correct PSI.
And what's the "SET" button for under the heating controls. .. .this makes the tyre pressure light blink . . . . any ideas guys??
Gareth
Hi Gareth,
I'm sure someone will correct me if I'm wrong but after changing wheels, tyre pressure etc.etc. the computer needs to be reset. If the tyres have the correct PSI, press and hold the tyre pressure button (the SET one) for a couple of seconds which will reset it - the light will then go out. Obviously it will pop back on then when the tyre pressure decreases. Hope this helps.
Jon
Press the button and hold it and it should note the current pressures (make sure they are correct first!)
Then a deviation from this pressure should bring up the warning. Mine works very effectively. :)
Lee
