HEAD UNIT trouble
hi before i removed and then re fitted my standard fabia vrs head unit it used to turn off when i took the key out of the ignition but some how it has just stoped doing it. i have to turn it off manually bit annoying any ideas ???
There is a setting in one of the menus. Press and hold the TP button and you can then cycle through some normally hidden settings - one of them is somehting like IGN and, when set to "ON" should enable the on/off with ignition function.
thanks mate will try it next time the car is out of teh garage cheers
