How to replace the heater panel illumination bulb on the MK I Octavia
Edited by simonlb
a piece of small tube can, do the trick also, just take the mittle **** out, push the tube over the bulb and pull out the bulb.
reinsert the same way, just with some oil/silikone on the tube, so the bulb will get loose easyer.
That's the way the Haynes Book of Lies says to do it but I find this way an awful lot quicker - easily less than two minutes.
  • 4 months later...
fan switch out with pointy nose pliers remove bulb with pointy nose pliers replace bulb with pointy nose pliers
make sure lights are off lol
be carefull you need a very steady hand
ceri
