Remove B pillar trim
Hi. I've found a number of threads that get very close to telling me how to remove the internal B pillar trim so that I can access the seatbelt unit on a late 2003 Fabia estate, but not yet found the answer, so forgive me and point me in the right direction if its there somewhere. Otherwise, if one of you knowledgable folk can tell me how to do it it will save me from starting at the wrong end and breaking something!
Will
You'll find a couple of clips behind it which are a bit tight. I would start from the door seat edge and roll it off of the rubber, once that is done you can bend it enough to see behind and locate the clips. Using a fairly long flat screwdriver reach in and prise the clips from the chassis.
Thank you Stu, much appreciated.
